First PC Build - help with component selection
ymsbrocks
Ok guys taking the plunge and going to build my first PC. This PC will be used primarily for music, photo/video editing, Office apps and maybe some light gaming. I will put XP Pro on it for now but would like to upgrade to Vista in the next year or so. My budget was $500.00, and as you can see i have exceeded that a little. Anyway how do these components look?
CASE: Rosewill R230-P-BK Black SECC Steel ATX Mid Tower Computer Case $17.99
Newegg.com - Rosewill R230-P-BK Black SECC Steel ATX Mid Tower Computer Case - Retail
PSU: FSP Group (Fortron Source) AX400-PN, RoHS, 12cm FAN, version 2.2, 2 SATA, 20+ 4 pin, PCI Express, 400W Power Supply $43.99 Newegg.com - FSP Group (Fortron Source) AX400-PN, RoHS, 12cm FAN, version 2.2, 2 SATA, 20+ 4 pin, PCI Express, 400W Power Supply - Retail
MOBO: GIGABYTE GA-965P-DS3 (rev. 1.3) LGA 775 Intel P965 Express ATX Intel Motherboard $99.99
Newegg.com - GIGABYTE GA-965P-DS3 (rev. 1.3) LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
VIDEO CARD:GIGABYTE GV-NX73T256P-RH GeForce 7300GT 256MB GDDR2 PCI Express x16 Video Card $76.99
Newegg.com - GIGABYTE GV-NX73T256P-RH GeForce 7300GT 256MB 128-bit GDDR2 PCI Express x16 Video Card - Retail
CPU: Intel Core 2 Duo E6420 Conroe 2.13GHz LGA 775 Processor Model BX80557E6420 $189.00
Newegg.com - Intel Core 2 Duo E6420 Conroe 2.13GHz 4M shared L2 Cache LGA 775 Processor - Retail
RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ $85.99
Newegg.com - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
Total: $513.95
I will also pull an old 250G HDD and CDR from my current system. Any concerns? Any substitutions so i can get this under $500? Thanks!
