Binary Coder
i just bought anarctic cooling freezer 64 pro heatsink for my 64 3800+ (939) , then wheni went to see it i found that it had the PVM wire, now i know you can connect to a 3 pin also and the 4th pin just hangs over the edge unused, but i have a resistor (ages since i did electronics) next to it, so i cant connect, what should i do?
Is their a way of using an adaptor that will convert the 4 pin to a 3 pin, then i can connect it, thanks
