Sorry about the lack of information. It is a grinding sound. The system specs:
CPU-Z version 1.45
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Celeron
Codename Northwood
Specification Intel(R) Celeron(R) CPU 2.70GHz
Package Socket 478 mPGA (platform ID = 2h)
CPUID F.2.9
Extended CPUID F.2
Brand ID 10
Core Stepping D1
Technology 0.13 um
Core Speed 2690.2 MHz (27.0 x 99.6 MHz)
Rated Bus speed 398.5 MHz
Stock frequency 2700 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 128 KBytes, 2-way set associative, 64-byte line size
FID/VID Control no
Features
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001005h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Function eax ebx ecx edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F29 0x0001080A 0x00004400 0xBFEBFBFF
0x00000002 0x665B5101 0x00000000 0x00000000 0x003B7040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30372E32 0x007A4847
Cache descriptor Level 1 D 8 KB 1 threads
Cache descriptor Level 1 T 12 KB 1 threads
Cache descriptor Level 2 U 128 KB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000
MSR 0x0000002C edx = 0x00000000 eax = 0x1B10001B
MSR 0x000001A0 edx = 0x00000000 eax = 0x00000089
Chipset
Northbridge Intel i845GL rev. B1
Southbridge Intel 82801DB (ICH4) rev. 02
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 132.8 MHz (3:4)
CAS# 2.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Infineon (C1494E46494E454F)
Size 512 MBytes
Max bandwidth PC2700 (166 MHz)
Part number 64D64320GU6B
Serial number 023CAE3B
Manufacturing date Week 39/Year 03
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 133 166
CAS# 2.0 2.5
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS 6 7
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0A 02 40 00 04 60 70 00 82 08 00 01
10 0E 04 0C 01 02 20 C0 75 70 00 00 48 30 48 2A 40
20 75 75 45 45 00 00 00 00 00 3C 48 30 2D 55 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
40 C1 49 4E 46 49 4E 45 4F 08 36 34 44 36 34 33 32
50 30 47 55 36 42 20 20 20 20 20 20 01 29 03 27 02
60 3C AE 3B 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Monitoring
Mainboard Model P4G533LA (0x1F3 - 0xAEF9DA)
LPCIO
Vendor AsusTek
Model ASB100
Vendor ID 0x5CA3
Chip ID 0x87
Revision ID 0x8
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xB
00 00 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 08 00 00 00 00 00 04 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2560
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF0000000
Subvendor ID 0x1043
Subsystem ID 0x8093
Int. Line 0x00
Int. Pin 0x00
Capabilities
Vendor Dependant Capability
Offset E4h
Dump
00 86 80 60 25 06 00 90 20 03 00 00 06 00 00 00 00
10 08 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 93 80
30 00 00 00 00 E4 00 00 00 00 00 00 00 00 00 00 00
40 3C 03 00 00 41 20 10 20 04 01 00 00 1B 08 10 00
50 00 00 40 00 00 00 00 01 49 3E 00 00 3B 32 3B 30
60 08 10 10 10 00 00 00 00 00 00 00 00 00 00 00 00
70 22 00 00 00 00 00 00 00 25 04 40 2B 71 81 00 20
80 65 00 AF 00 AD 00 00 00 01 00 00 00 00 00 00 00
90 10 11 31 03 00 11 11 00 45 04 00 00 00 0A 38 00
A0 02 00 20 00 17 02 00 1F 00 00 00 00 00 00 00 00
B0 00 00 00 00 20 00 00 00 00 00 00 00 20 10 00 00
C0 44 40 30 11 00 00 0C 0A 00 00 00 00 00 00 00 00
D0 02 28 04 0E 0B 0D 00 10 00 00 11 B3 00 00 20 00
E0 00 00 00 00 09 00 05 11 0E 00 00 00 00 00 00 00
F0 38 0E 00 00 74 F8 00 00 40 0F 00 00 04 00 00 00
VGA Controller
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2562
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE8000000
Address 1 (memory) 0xE7800000
Subvendor ID 0x1043
Subsystem ID 0x8093
Int. Line 0x10
Int. Pin 0x01
Capabilities
Power Management Capability
Offset D0h
Version 1.0
Dump
00 86 80 62 25 07 00 90 00 03 00 00 03 00 00 00 00
10 08 00 00 E8 00 00 80 E7 00 00 00 00 00 00 00 00
30 00 00 00 00 D0 00 00 00 00 00 00 00 10 01 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 01 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x24C2
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000D800
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x10
Int. Pin 0x01
Dump
00 86 80 C2 24 05 00 80 02 02 00 03 0C 00 00 80 00
20 01 D8 00 00 00 00 00 00 00 00 00 00 43 10 89 80
30 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 27 00 00 03 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x24C4
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D400
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x13
Int. Pin 0x02
Dump
00 86 80 C4 24 05 00 80 02 02 00 03 0C 00 00 00 00
20 01 D4 00 00 00 00 00 00 00 00 00 00 43 10 89 80
30 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x24C7
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D000
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x12
Int. Pin 0x03
Dump
00 86 80 C7 24 05 00 80 02 02 00 03 0C 00 00 00 00
20 01 D0 00 00 00 00 00 00 00 00 00 00 43 10 89 80
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x24CD
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFFEFF800
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x17
Int. Pin 0x04
Capabilities
Offset 50h
Version 1.1
Debug Port Capability
Offset 58h
Dump
00 86 80 CD 24 06 00 90 02 02 20 03 0C 00 00 00 00
10 00 F8 EF FF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 89 80
30 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 00
50 01 58 C2 C9 00 00 00 00 0A 00 80 20 00 00 00 00
60 20 20 7F 00 00 00 00 00 01 00 00 00 00 00 00 C0
70 00 00 E7 0F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 10 00 3F 00
F0 78 BF 1F 00 88 83 00 00 60 0F 00 00 06 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0x82
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 4E 24 07 01 80 80 82 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 B0 B0 80 22
20 00 E6 F0 E6 00 E8 F0 E7 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00
40 02 28 20 00 00 00 00 00 00 00 00 00 00 00 00 00
50 02 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 50 26
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x24C0
Revision ID 0x02
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 C0 24 0F 01 80 02 02 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 01 E4 00 00 16 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 01 EC 00 00 10 00 00 00
60 80 80 80 80 90 00 00 00 80 80 80 80 00 00 00 00
90 F5 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 20 02 00 00 00 00 00 00 0D 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 40 00 02 00 00 00 00
D0 86 21 00 00 02 0F 00 00 04 00 00 00 00 00 00 00
E0 00 00 00 80 00 00 08 14 33 22 00 00 00 00 67 45
F0 0F 00 41 00 00 00 00 00 60 0F 02 00 00 00 81 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x24CB
Revision ID 0x02
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000A800
Address 1 (port) 0x0000A400
Address 2 (port) 0x0000A000
Address 3 (port) 0x00009800
Address 4 (port) 0x00009400
Address 5 (memory) 0xE5800000
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x03
Int. Pin 0x01
Dump
00 86 80 CB 24 07 00 80 02 02 8A 01 01 00 00 00 00
10 01 A8 00 00 01 A4 00 00 01 A0 00 00 01 98 00 00
20 01 94 00 00 00 00 80 E5 00 00 00 00 43 10 89 80
30 00 00 00 00 00 00 00 00 00 00 00 00 03 01 00 00
40 77 E3 77 E3 BB 00 00 00 0F 00 11 22 00 00 00 00
50 00 00 00 00 30 34 00 00 00 00 00 00 00 00 00 00
60 08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x24C3
Revision ID 0x02
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000E800
Subvendor ID 0x1043
Subsystem ID 0x8089
Int. Line 0x00
Int. Pin 0x02
Dump
00 86 80 C3 24 01 00 80 02 02 00 05 0C 00 00 00 00
20 01 E8 00 00 00 00 00 00 00 00 00 00 43 10 89 80
30 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x24C5
Revision ID 0x02
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E000
Address 1 (port) 0x0000E100
Address 2 (memory) 0xFFEFFE00
Address 3 (memory) 0xFFEFFD00
Subvendor ID 0x1043
Subsystem ID 0x8098
Int. Line 0x11
Int. Pin 0x02
Capabilities
Offset 50h
Version 1.1
Dump
00 86 80 C5 24 07 00 90 02 02 00 01 04 00 00 00 00
10 01 E0 00 00 01 E1 00 00 00 FE EF FF 00 FD EF FF
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 98 80
30 00 00 00 00 50 00 00 00 00 00 00 00 11 02 00 00
40 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 C2 C9 00 00 00 00 00 00 00 00 00 00 00 00
Communication Device
bus 1 (0x01), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x11C1
Model ID 0x044C
Revision ID 0x02
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFFEFFC00
Address 1 (port) 0x0000FEF8
Address 2 (port) 0x0000FF00
Subvendor ID 0x11C1
Subsystem ID 0x044C
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset F8h
Version 1.1
Dump
00 C1 11 4C 04 07 00 90 02 02 00 80 07 00 40 00 00
10 00 FC EF FF F9 FE 00 00 01 FF 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 40 00 00 00 C1 11 4C 04
30 00 00 00 00 F8 00 00 00 00 00 00 00 17 01 FC 0E
F0 00 00 00 00 00 00 00 00 01 00 E2 E4 00 00 00 00
Ethernet Controller
bus 1 (0x01), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000B000
Address 1 (memory) 0xE6000000
Subvendor ID 0x1043
Subsystem ID 0x805B
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 EC 10 39 81 05 00 90 02 10 00 00 02 00 40 00 00
10 01 B0 00 00 00 00 00 E6 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 5B 80
30 00 00 00 00 50 00 00 00 00 00 00 00 11 01 20 40
50 01 00 C2 F7 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Award Software, Inc.
version 3.16
date 08/05/2003
DMI System Information
manufacturer Compaq Presario 061
product DM173A-ABA S5200NX NA311
version 0n41411RE101ECHO 10
serial MXR3551129
UUID 0042DFAD-8931D811-A0688AE1-27278698
DMI Baseboard
vendor ASUSTeK Computer INC.
model P4G533LA
revision REV 1.xx
serial MB-1234567890
DMI System Enclosure
manufacturer Hewlett-Packard
chassis type Mini Tower
chassis serial N/A
DMI Processor
manufacturer GenuineIntel
model Intel(R) Celeron(R) Processor
clock speed 2700.0 MHz
FSB speed 100.0 MHz
multiplier 27.0x
DMI Memory Controller
correction unknown
Max module size 1024 MBytes
DMI Memory Module
designation DIMM 1
DMI Memory Module
designation DIMM 2
DMI Port Connector
designation PRIMARY IDE/HDD (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE/HDD (internal)
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (external)
port type USB
DMI Port Connector
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Parallel Port (external)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Serial Port (COM1) (external)
port type Serial Port 16550
connector DB-9 male
DMI Port Connector
designation Line In Jack (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Video Port (external)
port type Video Port
DMI Extension Slot
designation PCI 1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI 2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI 3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation AGP
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048 MBytes
max# of devices 2
DMI Memory Device
designation DIMM 1
format DIMM
type DRAM
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation DIMM 2
format DIMM
type DRAM
Software
Windows Version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Memory I/O Space, BA=0x00000000F0000000
Memory I/O Space, BA=0x00000000E8000000
Memory I/O Space, BA=0x00000000E7800000
Port I/O Space, BA=0xD800
Port I/O Space, BA=0xD400
Port I/O Space, BA=0xD000
Memory I/O Space, BA=0x00000000FFEFF800
Port I/O Space, BA=0xA800
Port I/O Space, BA=0xA400
Port I/O Space, BA=0xA000
Port I/O Space, BA=0x9800
Port I/O Space, BA=0x9400
Memory I/O Space, BA=0x00000000E5800000
Port I/O Space, BA=0xE800
Port I/O Space, BA=0xE000
Port I/O Space, BA=0xE100
Memory I/O Space, BA=0x00000000FFEFFE00
Memory I/O Space, BA=0x00000000FFEFFD00
Memory I/O Space, BA=0x00000000FFEFFC00
Port I/O Space, BA=0xFEF8
Port I/O Space, BA=0xFF00
Port I/O Space, BA=0xB000
Memory I/O Space, BA=0x00000000E6000000
Port I/O Space, BA=0xE408, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x2E
