On the front of my case, I have 2 usb connections, and an audio in and out connection. Theres also what appears to be a 1394 connection, but with no wires going to it. Cant think of any reason this would be there?
Anyway, the two sets of wires for my usb headers are labeled (-D , GROUND , +VCC , +D) in corresponding order wire colors are yellow, black, red, green.
In my manul for my mother board (asus a8n-sli deluxe) the usb connection are listed as:
(left pin) (right pin)
USB+5V / USB+5V
USB P7- / USB P8-
USB P7+ / USB P8+
GND / GND
.........../ NC
So I have no clue how to connect my usb cables, since the naming doesnt match up.
Secondly, the audio cables, labeled (SPKOUT R , SPKOUT L , MIC-IN , MIC-BIAS , GROUND , RETURN L , RETURNR)
In the manual, for 'front panel audio connector (10-1 pin FP-AUDIO) the m/b connections are listed as:
bline out L / line out L
.............../ NC
bline out R / line out R
+5VA / micpwr
agnd / mic2
Thanks for your help.
Michael
USB+5V / USB+5V
USB P7- / USB P8-
USB P7+ / USB P8+
GND / GND
.........../ NC
.............../ NC
+5VA / micpwr
agnd / mic2
Michael
