Gateway Computer Problem, please help
tay69lor33
I have a Gateway Select 1000 PC that I purchased in 2000. Here are some specs;
AMD Athlon 1000MHz
Windows ME
128MB Memory Module
40GB Ultra ATA Hard Drive
Lately I've been having problems. The computer always freezes. It seems whenever I attempt a somewhat complicated task such as viewing flash websites, watching a movie, or even watching music the computer will freeze. Occasionally the computer will just reboot itself without warning. I have formatted my computer so many times I could do it in my sleep. This led me to think that it couldn't be a virus or spyware because i delete stuff on my computer. I've tried updating Windows and everything. I thought maybe my hard drive is bad, but if i bought a new hard drive should this solve the problem? Please help!
Heat problems? Failing memory?
I thought maybe my hard drive is bad, but if I bought a new hard drive should this solve the problem?
If the drive has errors, a CHKDSK/SCANDISK should be able to find the major ones.
Windows ME
There's your problem. WindowsME is a universally accepted, ineffecient, buggy and outright horrible OS (even my Windows fans).
When you reformat, does it exhibit these problems right away or after you've started installing stuff (and the registry is a mess)
I doubt it has heat problems, i've had this computer for 3 and a half years and i've never had that problem. Scandisk doesn't pick up any problems. Even if Windows ME is really buggy, I didn't have this problem until recently. Yeah when i reformat if i try listening to music for awhile it will freeze.
I figured as much but it was worth mentioning
Virus potential? What are the processes running in the background?
Yeah when I reformat if I try listening to music for awhile it will freeze.
Although I'm reluctant to "blame" the harddrive (seems to easy), that might be a possibilitiy.
Yeah i thought it would be viruses too, but nothing is running in the background, and plus i've reformatted a number of times which would mean no viruses. Is it worth taking it into a computer shop, or what should i do?
Yeah I thought it would be viruses too, but nothing is running in the background, and plus i've reformatted a number of times which would mean no viruses.
1. Formats do not mean no-viruses
2. Viruscheck from a bootdisk gives the greatest chance of finding viruses. Second best is to run the virusscan during a seesion
How would i do that?
If you've got the antivirus cd, pop it in the drive and boot off the cd... most major antivirus cds are bootable and can do a viruscan during boottime to avoid the problem of boottime viruses
i did that and it didn't pick any up. However i made a new discovery, whenever my computer freezes it runs Scandisk, but the normal mode is selected not thorough. No problems are found. But recently i went into system tools and ran a thorough scan disk check and it found a few file errors that were fixed, but Scandisk quits responding when it gets stuck on a certain sector. Is this more evidence that i have a bad hard drive?
CHKDSK didn't work, it said
CHKDSK has NOT checked this drive for errors.
You must use SCANDISK to detect and fix errors on this drive.
So i downloaded Disk Checker 2.1 and it didn't find any errors.
By the way thanks for the quick reply.
Goto command prompt and type chkdsk C: /F replacing C: with the appropriate drive as needed... does that work?
that's what i have been doing lately, but i dont have another computer and parents don't think anything is wrong with this one. I think some computer guy is going to look at it. It use to be a great computer i could play games and stuff, now i can barely go to a website.
