hard drive issues???...need help
MoSpinach
Howdy all
I have a WD800AB 5400 rpm 80 GB hard drive. a few months ago, I was opening the case and accidentally tore a few of the wires on the IDE cable connecting the hard drive to my motherboard (model A7NBX-LA I believe). I was stupid and tried to turn the machine on anyway to see if it would still work...bad idea I guess. I can't recall exactly what happened, but I turned the machine off and basically disassembled the whole thing and left it sitting around until 2 days ago. I don't know if this occurrence is relevant to my present situation, though a few more-computer-savy-than-me friends of mine told me it shouldn't.
Fast forward to the present. Yesterday I purchased a Xion II tower (came with a 450 pow. supply), new IDE cables for both the hard drive and my 2 ROM drives (single drive cable for the hd and dual drive cable for the ROM drives), and a new 128 mb graphics card. I put everything in place, hooked up everything to the motherboard, and so forth, turned the machine on, and unhappy times for me.
It's originally an HP computer, and when it first turns on, the first main thing that appears is a completely blue screen with the HP company logo in white....it only gets that far now and goes no further. It freezes at that point, I can't even get into BIOS or system recovery, even if I'm hitting the F1 or F10 buttons as it's booting up. I tried all kinds of things: I switched the IDE cables, putting the dual drive one on the hard drive alone as a test, trying to boot with the windows XP Home upgrade CD, switching the IDE cable slots on the mother board, and praying.
I already confirmed that it wasn't the graphics card, cuz I can take that out completely and still get the "blue screen of death", which also happened with any sort of IDE cable combination, so I doubt it's the new cables either. Does anybody have suggestions or outright beliefs of what the problem is and what to do? I don't want to just resign to it being the hard drive and having to buy a new one, especially if there's something I can do about it. Lemme know if I need to divulge more info or if y'all got questions. Thanks all.
nothing at all...when i first turn on the power, everything starts whirring away. the monitor displays the stats for my new graphics card (i still haven't installed the driver for it because...y'know...i can't even get windows to load). Then it goes to the HP logo screen and then nothing. No change in sounds happens at any point, even after it freezes. the things freezes even if i'm repeatedly hitting F1 before it gets to the logo screen, though it will saying "entering setup..." on the logo screen if I do that, but it obviously doesn't get to the setup.
Have you let it sit for 10 min? Maybe work it out? I know when I put a new hd in it takes a while to work everything out...
Disconnect the HD, place a bootable floppy disk and boot the computer - this way you could determine if it was the hard drive or not.
