Hard Drive Problem + Re-occuring boot problem.
aaaaaaaaaa
Dell System Dimension 4550 Series
Pheonix ROM BIOS PLUS Version 1.10 A08
I just put a new hard drive in, and now the computer refuses to boot whatsoever. The only screen I get to says.....
Diskette Drive 0 Seek Failure
Primary Hard Disk Drive 1 Not Found
Secondary Hard Disk Drive 0 Not Found
Secondary Hard Disk Drive 1 Not Found
Strike the F1 Key to Continue, Strike F2 to Run the Setup Utility
Striking both F1 or F2 does nothing, you just hear some kind of error beep.
I've always gotten this message with the old hard drive, however hitting F1 actually let you boot into that hard drive. I want to be able to boot into this hard drive, and figure out why I get this message whenever I boot so I can 86 it all together.
This computer was previously owned, so I don't know much about this history of the old hard drive. I know the hard drive I'm trying to put in is pretty old and quite handled.
Here is the old hard drive.
http://www.hitachigst.com/hdd/desk/ds120gxp.htm
Here is the new hard drive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144102
If you have two drives on the same cable. The Jumpers are on the back of the drive where the connectors are. Set your main drive as Master and the other one as Slave, most are marked.
Problem solved.
The OS wasn't loading because the OS on there was from my HP about 5 years ago. I hooked that hard drive up as a slave with another hard drive and I was able to safely get all my data, then reformat.
Thank you guys very much for the help.
