Hard drive problem
sandeep_kailey
Hi,
Before installing XP on my computer . i created a partition of 35 and 65 GB . But after the installation when i go to my computer it is showing only one drive of 35 GB.
its not showing 65 at all .
What should i do . do i need to reinstall xp .
thanks
You made two partitions but only formated one most likely. Go into system manager and you can format the unallocated space so you can use it.
