Hardware: Boot Problems., Power Supply?
bakura82
Compaq Evo D51c (HP lists as D510 Minitower)
Previously: Time seems to have made the problem worse. Originally, I could get to the RAM check with some jimmy rigging. I could not boot, but I did verify the problem is not RAM related.
Currently: No self test POST beeps. Black screen only.
Checked the power supply and came up with weird values:
Compaq 220 watts power supply, PFC, dual voltage
OEM Part #277910-001
Replacement part #277979-001
BRW (5.9V) | BRW (6.0V)
BLU (0.0V) | BRW (6.0V)
BLK (0.0V) | BLK (0.0V)
WHI (0.0V) | RD (10.4V)
BLK (O.0V) | BLK (0.0V)
BLK (O.0V) | RD (10.4V)
xxxxxxxxx | GRY(10.3V)
RD (10.4V) | GR (10.3V)
RD (10.4V) | OR (23.3V)
I don't know why the orange line is 23.3V. That makes no sense to me. All the ATX diagrams I have seen show a max of 12V. Also, the Peripheral Power
Connectors are outputting 23.3V.
Does this mean my power supply is gone? If so, I have spares, but for different comps. What do I need to match so I can make sure another supply will be compatible?
Thanks!
Esteban
That's quite strange... I don't know the pinout's off the top of my head, but I know there should be a 3.3v there as well. Assuming these weird voltages didn't fry anything, a new PSU should fix it...
I figured as much. I have some other PSU's, but I am not sure if they are compatible. What's the best way to make sure I don't make something go "pop"
Still no POSTing...
I found an older 300W supply of mine. I plugged it in and the crazy thing is that I am getting all the same voltages I posted above +/- 1. Is it possible that my mobo is telling these power supplies to do something different or something. THis makes no sense to me. :/
Should all I be plugging in is the "main" 20 pin cable?
