Having problem with my fans not turning on
real
The case is the Phanteks Enthoo Pro and the fans are Noctua 140mm each. There are 5 Noctua fans and they are connected.
First of all, thank you WhoX for your quick answer.
The manufacturer of the motherboard is EVGA and it's the Classified for the 6700K Intel processor. The power supply is a 1,200 watt Platinum EVGA.
Couldn't find much of a manual on Phantek's site, but I did manage to find this. Did you plug the fans into the mother board or to the case Fan/PWM Hub pictured below?
The fans are now connected to the motherboard and they work.
Thanks so much guys. You don't know how much I'm thanking you guys, since this service is for FREE. Now I need more help: I broke one of the PCI Express slots accidentally and ordered a new board. Now my question is: with what do I clean the thermal paste and which thermal paste should I buy?
If all you did was break the retaining clip then the slot should still work. I had an old board where the clip broke off and slot still worked.
The computer is turning on, but I'm not getting anything on the screen. I know the video card and the monitor works.
Now that I can view the picture, was on my phone earlier and every time I tried to view picture an ad would appear. So the slot has broken away from the board, definitely need a new board.
To remove the existing thermal paste, use Isopropyl Alcohol and a lint free cloth. Then use Arctic Silver 5 thermal paste.
