Headphones sound wrong. What's causing it and how to fix if possible?
Stroyed
So I was playing a game and I started getting angry. My angry really kicked in and I went stupid and started smacking the sides of my headphones. Now they sound wrong. It's hard to describe what it sounds like, but if you have the Realtek drivers, go to enhancements and set the equalizer to rock. It sounds similar to that. I plan on looking at it tomorrow to see if I can fix them. I'm 97% sure the cause was me smacking them so I assume something on the inside must have moved, causing the problem. I'd like to know two things. One, what part specifically is, or could be, causing. Two how, if possible, would I go about fixing it? Any help is appreciated. And yes, I know I overreacted, and yes, I know I should really start using techniques to calm myself down.
