Help! 2 problems!!!
When I start my computer up I get this:
http://img237.imageshack.us/my.php?image=untitledyt8.jpg
And it's happened twice now, but my computer restarts itself out of no where. Then when it's back up and running it says, your computer has recovered from a serious error, help!!!
Hey Jpeso2525-
It's really hard to read... but apparently it's some software's ".DLL" that's corrupted and my suggestion is if just happened recently... and you recently installed this application(s) do a system restore and see if that fixes the problem.
Sometimes a corruption in the dynamic library file can easily be corrupted... try the restore method and see what happens.
That has to do with a realtec audio drivers, run a windows update, or roll back your audio drivers, alot of people are having issues with the new drivers, hopefully there will be a new update sooner or later to fix this, but for now roll back your current drivers to an older version.
