HELP! Browsing Problems!!
Stevie D
Since i have got BT Broadband i can only visit certain sites! If i try to visit sites such as www.boreme.com, www.uibs.co.uk, www.suprnova.org it will bring up the website however it only stays on for about 5 seconds and then goes blank! and i cannot access anything on the site all i can see is a blank window! Does anyone know what this strange problem may be! Much help would be appreciated!
Thank You!!!
Could it be the site is experiencing too much traffic? (try ping/tracert on the addy?)
You got a good firewall that will track port/processes? You can see where sites are trying to take you :)
Praetor said:
You got a good <a href="http://www.ntsearch.com/search.php?q=firewall&v=55">firewall</a> that will track port/processes? You can see where sites are trying to take you :)
I am using McAFee!
