help help help
Something Funny
so i booted up my laptop just a few minutes ago and im getting this message...
IDE #0 ERROR
CLEINT MAC ADDR 000E 7B 38 46 90 GUID: 58A93A80 05C6 11DA 8050 B05D85032903PXE-E53
INSERT SYSYEM DISK IN DRIVE
PRESS ANY KEY WHEN READY....
so i indert the "system disk" or atleast what i think is the system disk and get this
intel boot agent fe v4.1.10
pxe-e61: media test failure, check cable
pxe-m0f: exiting intel boot agent
o btw...toshiba a55
what is going on here???????? please help...
Sounds like you don't have it set to boot to the CD-ROM... Do that and see about posibly running window's repair option first...unless you don't mind loosing your data on your HD.
um yeh...dunno how to do that...please explain
at this point i dont really care...i just want my computer back
got into the bios and poked around...everything look normal...now i got back in and there is no primary drive listed now..
it says:
built-in HDD= no drive
cd-rom= secondary ide(170h/irq15)
ok, that is what I figured. Either the HDD is dead, or there is some other problem that is not letting the lappy access it. That is why you get a System Disk #0 error, it lost the hard drive, and can't find the operating system.
Basically the only thing that you can do is to replace the hard drive
if you dont know how 2 take apart a laptop, it's going 2 be a pain in the ass lol. you really just got 2 remember where the stuff went.
Naaahhh...hard drives and RAM are easy in a laptop. Processors aren't ;)
good news! got ahold of toshiba and they said to take it to a authorized repair...there is one about an hour from here and im going up there anyways so it will be about a week...all covered by warranty too so double good news!
