HELP! I am building a new computer and need help.
AV24
1.FX 4100 Black Edition 3.6GHz Quad-Core Socket AM3+ Boxed Processor- $99
http://www.microcenter.com/single_product_results.phtml?product_id=0376784
2. M5A78L-M LX PLUS Socket AM3+ 760G mATX AMD Motherboard- $54.99
http://www.microcenter.com/single_product_results.phtml?product_id=0379475
3. 4GB DDR3-1333 (PC3-10666) CL9 Dual Channel Desktop Memory Kit (Two 2GB Memory Modules)- $19.99
http://www.microcenter.com/single_product_results.phtml?product_id=0353218
4. 22X DVD±RW Burner with Dual Layer Support - OEM- $15.99
http://www.microcenter.com/single_product_results.phtml?product_id=0382892
5. Barracuda 7200.9 500GB 7,200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive ST3500641AS-RK- $74.99
http://www.microcenter.com/single_product_results.phtml?product_id=0334235
6. Windows 7 Home Premium SP1 64-bit OEM (PC)- $109.99
http://www.microcenter.com/single_product_results.phtml?product_id=0361170
7. TC102 Mid Tower ATX Computer Case with 500W Power Supply- 36.99
http://www.microcenter.com/single_product_results.phtml?product_id=0357902
I would like to be able to do some basic gaming. (Ex. League of Legends, Sudden Attack). under 400$. I also need advice on a good graphics card that is not too expensive. Thank you so much!
You are gonna have to increase your budget some. You try using the power supply that comes with that case and you'll fry something. Also the 2 games you mentioned aren't that cpu intensive, really don't need a quad core.
Do you have to use micorocenter? What about newegg?
Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128458 78.99
Cpu - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103886 77.99
Memory - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193 29.99
Power supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026 44.99
DVD drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16827136236 17.99
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061 39.99
OS - http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986 99.99
Video card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102934 59.99
You are looking at $450 plus shipping.
