help!! i need help!
brutalgamer
When i play world of warcraft, for a while its lag free and suddenly the picture just freezes........:mad: and when i go out from wow the picture is all messed up and it says the driver or whatever it says doesnt work anylonger and i have to reeboot...... it happens from 5 minuttes playing to half an hour. WHAT TO DO?!?!?!?!?!
Your GPU could be the problem.. What graphics card do you have?
Edit- The video memory could be exceeded, which causes an error to shut down the game and display the "reboot message".
its an acer 1640
OS Name Microsoft Windows XP Home Edition
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name ACER-8BD37F0983
System Manufacturer Acer, inc
System Model Aspire 1640
System Type X86-based PC
Processor x86 Family 6 Model 13 Stepping 8 GenuineIntel ~ 2000 Mhz
BIOS-versjon/Dato Acer 3A05, 03.09.2005
SMBIOS Version 2.31
Windows folder C: \ WINDOWS
System Folder C: \ WINDOWS \ system32
Boot Device \ Device \ HarddiskVolume2
Locale Norway
Hardware Abstraction Layer Version = 5.1.2600.5512 (xpsp.080413-2111)
Username ACER-8BD37F0983 \ Day Time
All times are Western Europe (DST)
Physical Memory 024.00 MB 1
Physical memory 29.88 MB
Virtual Memory 2.00 GB
Virtual memory 1.96 GB
Space for the paging file 2.38 GB
Page File C: \ pagefile.sys
i am not sure but i think the graphic card is intel 915GM
its pretty old and i think its waste of money to change the graphic card
its an acer 1640
SMBIOS Version 2.31
Locale Norway
It's because of the GPU. It's too old and maybe doesn't support that much software.
The RAM should also be at least 4 gigs
Edit- Your PC is old as hell. My advice is buying a new one(You can get a good one for circa 6-700 bucks. or if you want to, build a new one. That's the two best things to do.
You don't want to waste time replacing stuff in your current PC.
And when you're getting a new GPU, my advice is buying one with 1 gig memory, then you won't get any errors, in most cases
