help!!! had this problem for quite some time... I cannot access the internet using the IE browser directly. When the program is executed, it will just hang. The only way is to go to other folders and change the link at the address bar.
then, whenever there's a pop-up or a new window is opened, the browser will hang. after some tme, the new window will pop out (but you can never see its contents) and you will have to close it first before the original window can be used (it will not be responding otherwise)..
any cures?!?! with this problem, i cannot access alot of info which WILL open in a new window...
thanks in advance...
feel free to clarify if i didn't state my problem clearly enough....
