help me! 3d games slow after OC! Settings right?
Mcky
Core2Duo E6600 2.4GHZ > 3.4GHZ
ASUS P5B-E plus (Overclockable mobo)
1GB DDR-2 800Mhz 4.4.4.12
377MHZ FSB 1:1 FSB:DRAM
Multiplier:9X377=3.4GHZ
vcore=1.400v
mem timings=4.4.4.12 (default stated on RAM)
mem voltage=default
cpu enhancements=off
pci lock=33.33mhz
pci express=101mhz
cpu cooler:coolermaster external cooler
PSU: Coolermaster extreme power 600w psu
video: 8800GTS 500/1600 > 630/1950
I have tested prime95 for 1 hour and everything is stable. Max load temp is 57 degrees. But 3d games are very slow!! Any ideas why??
Do you have a divider on the memory? i'm not sure cause i havent worked with c2d but 377 is an awfully high reference clock..
To put a divider on your ram is to make it run slower to compensate for high reference clock speeds but before we get more into that.. does the e6600 have a x10 multiplier? if so bring that up to 10 and lower you reference clock speed to 320-340. Then check to see if you are running alittle faster.
nevermind i didnt notice your ram.. hmm.. try going back to your vid cards stock speeds and testing some games out then.
My bus speed is 400mhz with a multiplier of 8.... No heat issues....
Vcore of 1.344
FSB of 1600.00
A higher FSB will normally yield 'faster' results. So long as your processor speed doesn't change int he comparison.
