Help Me!!! external hard drive issues
mk0825
i have a 320 gb external hard drive that is not working right. i think i downloaded a virus but am not sure. i cannot access the harddrive and an error message comes up (I/O device issue or somthing) there is no way to get in to it. also when i attach the ehd and look for it in my computer it says not responding and everything slows down and not responds's's's's. as soon as i yank the cable out the computer returns to normal functioning. i just want to access the harddrive to get my 200gb of music, movies and other stuff off. WHAT DO I DO, please help ASAP.
ps. im no computer whizz so keep it simple wheere possible.
Plug it into another computer and check if it's actually working. Obviously try all the other usb/firewire ports just in case too. Does it sound different? Is it spinning up?
Viruses in general do nothing. They slow up the computer a bit, but windows firewall is all I use and it's easilly enough unless you're on suspect sites all the time. P2P sharing software mucks up my computer a bit too, best to keep away from them.
I doubt it's a virus causing your problems though...
i downloaded 3 movies p2p and tryed to copy and paste them to the hard drive, about halfway thru pasting them a warning on the toolbar came up and it told me that it didnt work and to retry pasting it on the hd. if i deleted those movies from my documents could that make somehow fix the problem, maybe its a virus that doesnt let you read harddrives:confused:. it did read my ipod though.
