help me! plis give me sample of simple program using threads!
hiphop
well
actually i dont know anything about computer
i have a homework
its about making a program ( in C, java, or pascal (delphi?)) using threads
i have no idea about it
it makes me confuse
so everyone out there who feel smart and nice to help
plis help me
just give me a simple program that using a threads inside
and describe generally, what tjis program tells about, so that u can learn it and understand it
plis help me
I would strongly recommend reading into this more yourself, it can be daunting at first but once you get your head round things its a lot better have gained your own understanding than having someone do it for you, I am learning Java myself and have linked a guide from the Sun website which should get you going.
http://java.sun.com/docs/books/tutorial/essential/threads/
try here also
http://www.javaworld.com/javaworld/jw-04-1996/jw-04-threads.html
http://www.quepublishing.com/articles/article.asp?p=26044&rl=1
Regards
Mike
P.S. remember your program should look like some of the examples in the second and third link. Java provides a class "Thread" which is basically a pre-written piece of code that you can extend and then use within the program your working on.
Take a close look at the demo thread in the third link and try and modify it to suit your needs, read the other links before you attemp this.
If you dont want to go to the trouble of installing a compiler and checking for bugs then re-post your code back here once complete and someone can check it for you.
