DavidWright05
Hi, I completed my new PC recently and using both the BIOS and a monitoring program supplied with the ASUS MoBo, I am recieving warnings that my Power Fan is dipping under the "acceptable" level. Apparantly that level is 800 RPM, and it seems to hover around 795-815. Is this something to be worried about?
My MoBo (Asus P5b) Temp is 37 C
My CPU (Intel E6600) Temp is from 41-44 C
Are those alright?
Any advice would be great. I want to make sure i'm not melting my brand new PC. Thanks.
Oh I almost forgot to add:
My PSU = Antec TruePower 550W (http://www.newegg.com/Product/Product.asp?Item=N82E16817103931)
I am using 2 HDD.
Are those alright?
I am using 2 HDD.
