Help! Wireless USB Adapter With GREAT range?
inspiration100
Does anyone know of a Wireless USB Adapter that has VERY good range? By good, I mean very good and can be accessed hundreds of feet away. I have a crappy one and i'm completely fed up with it. It gets a signal strength of about 30, less than 100 feet away and is unable to connect to the internet. I want the best and I can pay the price.
Thanks in advanced folks!
That doesn't mean to say that it is the usb adapter, it could be your router that doesn't send a very powerful signal.
The best USB wireless router out there (by Belkin) has a maximum range of 30 feet. You are out of luck.
