[Help]Wiring case cable to motherboard
FullFlash
Hello Guys,
I already received all the stuff for the build except the CPU!
It's my first time trying to build a system from ground and I need to be pointed into the right direction.
to make it short I want to check whether I did wrong wiring!
Where should 1354 on the motherboard manual it says if I plug it into usb header it would damage the board.
where should I plug it ?
Hopefully the CPU will arrive tomorrow so I can get going :thumb:
Thanks guys
the power headers are fine. The 1394 is firewire, which your mobo does not have a header for, so just leave that be.
