It's pretty bad to be honest, I've had the PC for around 7ish years more or less and I've never been able to clean it properly, the dust build up is pretty noticeable, and so is the noise my PC makes now, and I was hoping if I could clean that out it may help. I didn't realise I'd have to put more thermal paste on to it though, but I've read you can get it cheap?
I've tried cleaning it while its still fitted but its just too difficult, even trying to fit a small brush between the fan blades to even move the dust is impossible.
