Help with front panel audio connecters
FrEaKMaN
Heya ppl ive finished making my computer and i plugged in the front panel into the JAUD1 onto my MSI K9N4 Ultra-F SKT AM2 motherboard. The mic and 2 USB ports work but i can't seem to get the headphone port to work. after connecting all the cables, the ones that are left over are, L-IN, RIN, GND, R-OUT, L-OUT, any ideas which one will help solve the problem? thanks
Most likely I would guess it to be a problem with your case. Possibly bad wiring or a bad jack. Otherwise, it could be something with your mobo, or are you sure that those headphones work?
yh the headphones r fine bcoz if i plug them @ the back they work fine....im gna try the L-out. ill let you know the results
