help with frustrating links wont open after right click
staf
hey folks
I just bought a new computer and i have an issue that id like help with please. When i right click on a tab in the task bar and then try and open it it wont open no matter how many times i click on it. so then i click on another tab and then i can open the tab. Anyone know whats happening here? it seems to do the same with links on Tidal, im using windows 11
thanks heaps guys
staf
What web browser are you using? Do you have any extensions installed for that browser that may be causing the issue. Can you post a video of what you are trying to do?
so if i right click on a tab in the task bar and then try and open it with a left click, it wont open no matter how many times i left click it, so then left click on another tab in the task bad and then go back to the one not opening it opens again,
Have you tried rebooting the computer? I haven't heard anything about this bug in windows 11. However, if you just click on the tab down in the taskbar it should automatically bring it up without right clicking anything. Not sure what to tell you to try.
