junwang0808
after using "speedfan " ( software ) i found out after running my PC for 1 hour the temperature of my PC is like this
check: 45C
burning: 82C
burning: 46C
burning HD0: 50c
HD1 : 0 C
is there anything i can buy that can keep my system cool? except water cooling?
thx
and i am using sapphire x1950 pro agp 512mb when it get hot its run really slow...
i am using the stock cooling fan .. so if i have to change the fan what should i change it to?
is it possible to install this on my sapphire x1950 pro agp 512mb??
http://www.newegg.com/Product/Produc...82E16835186002
so plz !!! help me out what should i get to keep my comp temperature down??
i didn't overclock it. i have 2 case fans one on the mother board one on the case.
i switched from x800 to x1950 which x1950 is suppose to run a lot faster but i hardly notice any difference. and after 1 or 2 hours just leaving the computer on and surfweb. it get kind of hot and when i run game it gets kind of slow. way slower than x800
i have a sony PCV-RS630G
PS is 400 W ( http://www.newegg.com/Product/Produc...82E16817104953 )
2 GB DDR corsair RAM
or should i just return it and get a x850xt PE?
do you have any benchmark software so i can test my result??
should i get another ARCTIC COOLING Arctic Fan 8 (AF8) 80mm Case Fan??? along with the graphic card fan?
thanks
check: 45C
burning: 82C
burning: 46C
burning HD0: 50c
HD1 : 0 C
thx
thanks
