Hi all, thanks in advance for any help you can provide me
<edit>
I need to know the following:
- Can anyone recommend a cheap (~75$) LOW-PROFILE graphics card? Check my computer details below!
- Would I need a fan if I added a 'better' graphics card? Any recommended? I need one that fits my comp. details please!
- Anything else I should know?
ORIGINAL:
I have a Dell Optiplex 745 Small Form, and I'm looking for a graphics card (~75$)
Currently, I have vista and 2gb of RAM.
Info on my comp: http://www.dell.com/content/products/productdetails.aspx/optix_745?c=us&cs=28&l=en&s=dfb
I'm looking to play a game called Entropia (http://www.entropiauniverse.com/en/rich/5326.html), which has system req. of:
* Windows XP or later.*
* 512 MB RAM.
* 1.7 GHz Intel P4, AMD Athlon XP 1700+.
* NVIDIA GeForce 6000 series or higher, ATI Radeon R300 Series, (96xx or higher.).**
* Latest NVIDIA driver - Get it here. Latest ATI driver - Get it here.
* Direct X compatible sound device.
* 3 GB of free Hard Drive space.
* Direct X version 9.0C.
* Broadband internet connection (ADSL or better).
My computer comes with:
Intel(R) Q965/Q963 Express Chipset Family
.. which doesn't work.
So I'm looking for a graphics card that meets the system req. (above) and my computer. If it matters, my comp. has 275V of power.
I'm sure it's not the Vista thing, and if it is, I can change my computer to XP (Yes, I'm that desperate.)
And I've tried it on the lowest settings, everything works, just the characters are black.
Thanks!
Need help ASAP!
Any help works! Just post a reply!
I'll stop typing stuff here now..
<edit>
ORIGINAL:
* 512 MB RAM.
Thanks!
Need help ASAP!
