help with wireless network for 2 pcs
stratford
i am looking at going wireless using 1 desktop 1 laptop using a wirless access point router im i right in thinking my dektop will be connected to the router with cat 5 and only the laptop will be wireless. i cant seem to find a detailed diagram to follow they all seem to include seperate access points and radio waves no wiring can anyone point me in the right direction.thanks in advance.
I got the same setup. All you need is a wireless router, connect the modem (DSL, Cable)to the wan port of the router, connect your desktop computer to the other ports. Check with your ISP wether they use dynamic or static IP. If its dynamic configure your router to dynamic IP. Change your desktop computer and laptop to use DHCP and your done.
Here is a link to a nice Netgear 108Mbps wireless router, its got a diagram of a home wireless network.
http://www.netgear.com/products/details/WGT624.php
will this do the job
will this do the job 108mbp wireless broadband router 802.11g is that all i need nothing else/laptop is already wireless enabled.
packard bell
pentium 111 600mhz
256 ram
hercules 4000GT graphic
cd-rom/cdrw 4*4*32
intel 82801AA ac97 audio controller
mr2800 data/fax modem
20gig
advent7038 laptop
athlon 2500+
512 ram
ATI radeon 320m
pioneer dvd-rw-dvr-k12d
*86 family 6 model 10 o authentic AMD 1855mhz
60gig
