JlCollins005
Alright i have a laptop im fixin for a friend well at first i thought it was gunna be easy because it was just a corrupt windows file.. well i started the xp install went to format hdd and it locks up, so i used a diagnostics disc that geek squad uses, well when it gets to the hdd test it blue screens or locks up.. well heres the weird part i used partition magic to format and create the new partition and stuff.. run windows install and it copies the setup files but after reboot it gives blue screen again.. im wondering if there is ne way to determine where the problem is and if i could fix or block the problem out with a smaller partition or something.. ne advice is great thx
