hrm... need some help for core duo build
footballstevo75
i have decided to build a C2D system soon, not sure about the e6400 or e6300, but i know im getting one of them
so heres what i need opionions on-
mobo- i really like the Asus p5b deluxe with the wifi for my lappy
RAM- no idea, 1 or 2 Gigs? what kind for overclocking? best value?
GPU- another no idea, completly lost, not a gamer, would like to run google earth at a decent clip, a little video editing,
I also want to watch TV on my pc, through a tv cable connection, should i buy an add-on card, or get one with it on the gpu?
soundcard-needs to be cheap, decent sound
PSU- got a 500W, that enough?
case- got that taken care of
DVD-cheap lightscribe??
HD- i was thinking a small raptor for windows, and a 250GB sata?
um is this possible in the range of 1200?
no monitor, mouse, keyboard, speakers, nothing except the pc
if i had to get it under 1200, what should i sacrifice? the raptor?
thanks guys!
Easy for under $1200.
E6300
Asus P5B or Gigabyte GA965P DS3
1-2GB Corsair DDR2 667 or DDR2 675 (or DDR2 800 if you have the money)
7600GS graphics
Separate tv tuner card
Creative SB Audigy 2 ZS
looks pretty good to me
is the 36GB raptor enough to put my windows and programs on?
also, is their a cheaper sound card available?
I would try to go with a x-fi extreme music. Other then that it looks good. Might consider e6300 and overclock it to save some money and upgrade vid card a little.
thanks guys
when it comes closer to building day, i will be posting more often on this, i just wanted a general idea, any other suggestions welcome
and i think im gonna take the e6300 and overclock also
A 36GB raptor will be enough for windows and a few programs, right now I am using around 60GB for my windows partition on my computer.
well first of all, i am going to build it myself like I have all my pc's
and would I notice a difference if I put windows on a sata II hd instead of the raptor?
also how should I configure the raptor and HD for my music and movies
