I have a small problem...
Danda
Alright so I bought a computer form someone awhile back. It works great only with a few problems I been wanting to fix.
First: When I chat in Vent, my mic makes a few fuzzy noises but it works. Now when I play TF2 or any other game that uses a Mic, everyone wants to scratch their ears out. I tried fixing the settings but itdoes not do alot of help.
Second: When I play a Online game, my Ping goes Crazy! When I play TF2 my Ping shoots up to the 300's! And for WoW it goes from 150-500. Someone told me its a RAM issue but I am not sure.
Third: My Head phones. I only hear on one side of my ear; the right ear. I cant hear anything on my left at ALL. This is not a MAJOR issue, but it gets annoying at times.
If someone could help me, I would really appreciate this! Thanks again all!
-Danda
P.S. Here are the specs for my computer I have atm
Motherboard: Gigabyte GA-p31-DS3L 45nm and 1066mhz ddr2 support
CPU: 3.4ghz Pentium D 950 with stock cooling
Video: Asus Radeon x1950pro 256mb GDDR3
Ram: 2x 1gb Gskill PC6400 DDR2
HDD: 160gb seagate 7200rpm sata x2
PSU: 550w Coolmax
2x extra usb 2.0
Windows Vista home premium 64 bit
Well wait for someone smarter then I to reply to confirm but......
Mic/Headphones could just be you have a crappy on-board sound card...easy fix buy a sound card. should fix the first 2 problems.
Another trick is try a different jack and enable the new ones for mic/sound. You might have a bad jack. (which a sound card fixes too)
Ram far as I know does not effect your ping only loading cities etc would ram effect in WoW...your LAN does.
Several things could screw it up...WoW High Pop server = 100-150 avg ping on Blackhand.
Have you tried to update your motherboards drivers? Could be a issue with old drivers might be limiting your internet.
I dont know if I did. If you can , please link me to where I can DL Motherboard Updates?
And I may go out and buy a new sound card....
First Issue: You mic is most likely dying or is just not good, what maps do you play on in TF2, I think I have heard you ( no offence)
Second Issue: Your online ping could be several issues, most likely crappy broadband or if you are on dial up. A bad connection is the worst ever or you could have the settings up to high, when you play WoW, are you on a server close to home?
Third: Same as your mic, it just isn't good. Or maybe it is, I find sometimes that just turning it around makes a world of difference.
Hope I helped.
I have 2 head phones I tested. Neither of them work on TF2 but work on Ventrilo. I am |DI|Danda didn't mean to be known :P
I have a wireless connection. my provider is Cox and I use Linksys as my brand to use for Internet.
Ill test it out by turning it around. *Sigh* this computer is great, but sound is pissing me off...
