IE10 problem please help.
My boss is using IE10 and is adamant about keeping it, big mistake in my opinion.
I am having trouble with it, every single download is detected as a virus and deleted. I am unable to get around this problem, cant even download chrome or firefox cause it detects them as a virus. Anyone know how to get around this? I have looked on google but their answers are no help.
Try transfer from another computer
Try to download the full installation files for firefox from another computer and transfer to that one and install.
What antivirus software do you have? It's also possible that the machine is infected.
well I thought it was protected. I had an up to date version of McAfee however it seems that it wasn't enough to stop this bug. I found a process called XTray.exe and was informed it was a Trojan. not having a lot of luck removing it though. I deleted all its files and registry elements and am now running anti malware software. hopefuly it will fix the issue
Please do the following as you may need to run rkill to temporarily kill the infection to run software that will kill it totally.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Vista and Windows 7 users must right click on the hijackthis icon and click on run as. If the run as option doesn't appear then press and hold the shift key while right clicking on the icon to get it to appear.
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Get rid of McAfee - it's rubbish. The free ones out there are better. Microsoft Security Essentials and Avast Free are both better than McAfee (and less bloated).
