I have virgin media cable broadband size L (4mb) at home with the standard cable modem which was provided by NTL few years back and a Linksys WRT54G broadband router. All works perfectly have one PC directly connected to router and another PC and a laptop connected wirelessly. DHCP assigns each computer with an ip address 192.168.1.101 etc.
My friend next door has cable broadband size XL (10mb/20mb not sure if it has been upgraded yet or not) he also has the same modem which was provided by NTL few years back and he has a very similar router the Linksys WRT54GS(one with sppedbooster).
The problem first occurred he tried to connect his xbox 360 to his wireless router, It wouldn’t assign an ip address, whereas if he connected to my router he had no problem at all. This was strange I thought because I set up his router and all the settings were the same as mine at home. I then tried to connect my laptop to his router, and the DHCP wouldn’t assign me an ip address, it either gave ‘invalid ip address’ or assigned me a private something address starting with 169.1…… and it would say ‘limited or no connectivity’ – which was no connectivity. We worked out that only one piece of equipment could be connected at once to his router, so the xbox would work if you disabled the network connection on my frinds PC which was connected directly to his router.
The only thing I could think of was that the router was faulty, so I swapped over the two routers and too my surprise my router was now having the same problems connected to his internet connection and his router was working perfectly on mine!!!
It cant be the router as I’ve also tried a netgear WGR614UK as well and also the same problem on my friends connection and no problem on mine!!!
anyone have any ideas what may be the problem with my friends connection??
Anyone experienced the same problem??
