Laptop fan won't adjust speed
Regardless of how hot my HP Dv6707us gets, the fan won't "shift gears" to a faster spin. I've checked the HP site several times for BIOS updates, but I've got nothin'. I heard about a program called "Speed Fan", I installed it, but it doesn't really do anything for my laptop. Please help. This thing roasts! (oh, and i've got a chillpad, it doesn't help that much)
I do not think there is a way to up the speed, it is probably already at its highest spin rate. And when you say hot, if in speedfan, i think it should tell you your CPU temp, if its around 60 then its ok for a laptop, my laptop, when playing high demanding games always prety much burned, if the laptop will get too hot, it will shut down, so if it is not shutting down then it can handle it!!! and chillpads do not really do anything!!!
It does shut down because of heat.
When it was new, the fan would spin faster when it got hot. There was a significant difference in the noise of the fan. Now, it chugs along at a normal operation speed nearly all the time.
When was the last time you disassembled the laptop to clean all the dust out of the heatsink fins and fan? I do mine twice a year usually. Never less than once a year. This probably won't help your fan speed issue, but at least it will keep your laptop running cooler.
I yanked a huge hairball out of the fan a couple of months ago. It was the first time I'd been in it. I suppose I could go back in and blow out some dust, but dang, it's so frustrating that the fan won't kick in to overdrive.
I opened up an HP dv series laptop a few months ago, the fan/ heatsink was clogged with dust/ hair (it had never been opened before). If you put your hand in front of the fan (or fan exhaust) do you feel air being blown out?
I found this page, didn't read it myself yet, but seems pretty useful.
Yes, it does blow air. In fact, the fan had stopped altogether earlier. That is what motivated me to have a techie friend help me open it. We yanked a ridiculous hairball out of the fan (cats, you know) and the fan resumed its operation upon reassembly. It has just never changed speeds like it used to when it was new.
I had to do a complete wipe on this unit and reinstall Vista 32 a few months back. The fan issues began after the wipe... and the hairball.
I'm certainly no expert, but as you mentioned earlier, it sounds like it might be some sort of driver/bios issue.
Not related to fan speed, and I don't know the configuration of your fan and heatsink, but when you pulled the hairball "out of the fan", did you also pull whatever hair/dust that would have accumulated against the heatsink fins?
On my Toshiba (which is probably configured differently than your HP), much more dust is found against the heatsink fins than around the fan, and the heatsink fins are quite a distance from the fan itself. Just a thought that you maybe hadn't gotten all the hair/dust.
I'll have to take it apart and look. But I don't possess the appropriate knowledge or tools to do it alone. I've got a bud who can help me. I'm getting better at this stuff, but I've got a ways to go.
I'm hoping yours is easier to get to than mine. Mine is a real bear, and requires MAJOR disassembly. Having never taken apart a laptop before, I was more than a bit apprehensive about tackling it. Fortunately for me, there is a website which has step-by-step, almost idiot-proof disassembly guides specifically for various models of Toshiba laptops. Unfortunately, I know of no such site for HP laptops.:(
It's always nice to have a friend that can help out though. Just wish someone could post a cure for your fan speed issue.
Have you tried asking in other laptop forums yet?
Yeah, I tried in another forum, but it wasn't as populated as this one. I'm just going to stick here for all my questions, advice, etc...
I have never tried Speedfan on a laptop but in desktops it will show you the actual running speed of the fans. If its flat out, that's it.
You may be able to adjust fan speed in the BIOS. Whatever you do, you should check the fan speed before and after so you can tell if changes have really occurred.
I never thought of that. If the laptop is so prone to overheating, perhaps the fan is going full bore all the time.
I wouldn't go rummaging into the BIOS just yet even if you're trying to learn! Check what the current speed or range (in rpm) really are and post for comment. If there is a utility on the laptop use that, otherwise run Speedfan which you have already installed.
The noise a fan makes can be affected by the amount of crap that is deadening the sound and reducing air flow. I'm sure there is quite a variation in speed during running and between manufacturers but 1800-4000 rpm should cover the normal range in most.
SpeedFan doesn't actually recognize my fan. It does tell me my GPU is >60C and the CPU is, too.
That's a pity. FYI here are generic instructions for changing the fan speed in BIOS. Some HP Pavilion netbooks have a variable speed setting in the BIOS, System Monitor tab.
You could also look in Control Panel / Power Options for any processor speed settings. The faster the cpu and fans run, the more battery power is going to be used and the noisier it will be. The more intense the application, the hotter the PC will run.
If you are having trouble with the fans getting bunged up, keep away from carpets, pets and other dirt and hair sources.
I followed the "access the BIOS" how-to. I was able to get to the screen, but nothing else. None of the F-keys did anything but beep loudly, except F10 (which was the only way I could exit the BIOS, esc didn't work, either).
I was able to access the "Diagnostic Log" by hitting enter, but there was nothing there.
I have attached both screens of the BIOS I could access.
