bill of oz
i have a compaq laptop with xp on it....when i try to boot it comes up with this....
windows can not boot because the following file is missing or corrupt
<windows root>\system32\hal.dll
replace or re-load this file
i have booted the computer using an xp install cd, and when i push F3 to try and repair it says there is no hard drive detected on my computer and setup can not continue....
i then tried booting using a dos startup cd and it will start up to the a: prompt.....when i type in C: it says invalid drive spec.....
next thing i tried doing was booting with a windows 98 startup cd....when it got to the a: i typed in C: and it went to the c drive this time.....but when i type in "dir" to see the drive contents it only lists ONE directory called "recover" even though i have LOTS of other things on this drive it doesnt list them or show them.....
i ran scandisk and it scanned the drive and also did a surface scan and came back without any errors or bad sectors.....any ideas as to what i can try next? im lost now....
