linksys wireless router and direcway problem
supersly_jones
i can run the net directly from modem with no problems but i bought a new router and for some reason the install program wont recognize the router....anyone had a problem like this...i have no idea what to do
what install program? Direcway? I think what your saying is your using a local program (on your pc) to try to log into your internet connection, while using a router? The router logs in for you... You need to login to the router and set it up to connect to your direcway... probably http://192.168.2.1 or //home
yes i went to 192.168.0.1 and did all of it just the way it said entered all my information for ip address and everything i use without the router and it works fine...but with it...no go
So when you plug into the router... did you remove the settings from your pc... So it does not reuse the same information it was trying to connect with before? You would be basically be telling your pc to use a specific ip as well as the router your plugged into. Remove the ip from the pc internet connection box and the subnet..... Just make a new connection saying it connects automatically..
