Mass Effect 2 sound problem.
dirtbikeryzz
Ah the wonders of pc gaming, problems with 3 of the 4 games installed this week. Any ways on mass effect two the sound when people talk sounds like its way in the back round and you can't make out what they say. Tried different drivers for my gpu and still no luck. Its weird because the sound when your not in a conversation with someone or a cut scene sounds fine.
Just found a patch 1.02 but it keeps saying mass effect 2 isn't installed. Is it getting confused because its in program files x86?
If your using onboard sound, make sure you've got the settings in Mass Effect configured to the most basic option.
Open the patch file's directory, if its not in the same as the Mass Effects, theres your problem. If it is, i'd try downloading from a different location and re-installing it.
Is it any good by the way?
