max gpu temp and g-card temp for x850 pro
Bradan
im overclockin my 850 pro a lil more
whats the max temp i should go for the 850x pro's core
and whats the max temp i should go for the card itself?
umm liek 45 idle 70 load
how long should i scan for artifacts for before calling stable?
i keep trying to use the find max clock on ati tool and it wont push above 575mhz clock, because it hits 71c and starts to back off.. why?
edit, nvm looked at log theyre are sum artifacts
