Monitor/Graphics Card Problem. Help plz !!
c_style
Hi guys,
I have a very big problem, I got a new PC with
an AMD athlon 64 3000+
2GB DDR400 RAM
256mb Radeon 9250 graphics card
19inch Samsung TFT screen
I have problem when I play my game "Need for speed Underground"
the screen switch off after a few minutes.
I had the same problem when I try to log in, it shows the windoz loading
and it switch off just before the login screen appear, but that stopped
since I disabled the second graphics card that was appearing in the
device manager, which was showing two of the same card.
I tried to install ati catalyst center but I the screen switch off just before the login screen, when I uninstalled it everything was ok.
Please let me know, I'm really desperate. I know you are all busy
for christmas and new year, but I just wanted to give it a try.
I would be very grateful if you could give me some advice or help
me to fix this problem. Thanks a lot
P.S: Sorry for the bad english :o
Best Wishes
C Style
I think the ATI 2 graphics card thing is how they handle the card having 2 video out ports. The monitor turning off sounds like it's trying to run a resolution not supported by your monitor.
