Motherboard Audio Connection Problems
ajw06
I am new to computer building everything works fine but when i went to connect my cases front audio connections to the motherboard i am lost.
can you help?
Here is a scan from my motherboards manual and a list of things i need to connect.
Here are the connectors i need to connect:
Mic Power
MIC in
L Out
R Out
Ground
R Ret
L Ret
Thanks.
oh sorry it is upside down must have scanned it the wrong way round, can you label the picture that says JAUD1 with what goes where. soz about the picture
Here is the picture, if it is too small then right click and save the image, you need to do that to label it if you don't mind then post the new version with labels of where i should connect various connectors.
sorry if this isn't clear.
