Mount problem
Status
Not open for further replies.
neohobeo
Hello, i would like to start out and say, ye i am a pirate, and so what ?
The problem is that when i try to install a mounted game, then the installation just stops, at a wich procent, and then it wont go further, can anyone tell me what the problem is, it doesnt say anything, its just stops.
There is probably an issue with the image you downloaded. The issue is that you stated you pirated a game and are requesting help with it, which per the rules, we can't help you with.
Then in the theory i could just say that its not a downloaded game, but a backup of a game, then i could get help ?
But no i dont think its a issue in the file, because it did it with another game to, and sometimes it will go furter than 24,9 %.
The only thing I can think of is a corrupt image, or perhaps a file was incorrectly copied on the original image. Were both games pirated? If so, chances are you just got a few bad images. I would say the same thing if it was a copy of a game you actually own.
Why dont you go and buy the game your noob , why should we help you pirate games when all that will do is force the prices of games up for honest gamers.
You could say that but then a lot of time would be wasted helping you with what has a good chance to be simply a corrupt pirated copy (that no amount of legitimate help can fix).
As OMEGA said, if you were to post saying it was a legit copy, we'd still say corrupt image and suggest recreating the image. Theres not much else that can go wrong with mounting a legit image on using a legit program.
Status
