mouse problem Help
robina_80
hi people,
when I play MoH Airbourne my look when i play the guy is looking down on the left and whenever i want to look straight ahead which is the default were its meant to be, I have to keep rolling the mouse up to look up or straight ahead and if i dont keep rolling the mouse up my view goes back to looking down. can anyone help please
its not my mouse because i played CS:S and its fine
That's a glitch being seen in the game itself there. You will most likely have to reinstall it fresh to see that corrected. If the game has neen installed for some time one of it's files was probably damaged or simply not loading properly. If it was just recently installed look over the software disk to look for any finger marks or scratches.
A good ole addon controller ahhaaa....! Well at least you didn't have a need to reinstall the entire game there to correct a program glitch. But an external controller is something to consider as you found out there. I never use those or joy sticks for gaming here to end up seeing fewer problems overall. I had one for an old WIN95 system and ended up tossing it anyway.
