HI. My name is Eric. I’m new to the forums and am going to attempt my first pc build over the next few months. I’ve read up on a few sites what to look for and got a mod book to read though, so I’m not completely in the dark. I have a friend at work that recommended newegg.com to me for parts, so everything I priced is there.
The PC will be used for net surfing, I-tunes, DVD watching, games, nothing to hardcore, but I want it to last a couple years if possible. I do want to be able to have it run to my HD-TV. A great video card to play games and DVD/Blue Ray movies at top quality is a must. Learning how to build it should save money in the long run if I know what it is capable of and when to upgrade or replace.
Here is a breakdown of what I’m looking to get-
(all going in an Antec Nine-Hundred case that I already bought)
CPU- AMD Athlon 64 X2 6000+ Windsor 3.0GHz http://www.newegg.com/product/product.asp?item=N82E16819103773
Cooling- um…look at the case. LOL, do I need it? I will add a CPU fan/heat sink, the Video card has a fan.
----- ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler http://www.newegg.com/product/product.asp?item=N82E16835185125
Motherboard- ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD http://www.newegg.com/product/product.asp?item=N82E16813131013
Video Card- XFX PVT80GGHD4 GeForce 8800GTS 320MB 320-bit GDDR3 http://www.newegg.com/product/product.asp?item=N82E16814150173
Sound Card- motherboard has 5.1 on it, will upgrade later if needed
Speakers- have a 2.1 system from old pc, will get 5.1 off e-bay later
OS- Microsoft Windows XP Home With SP2B http://www.newegg.com/product/product.asp?item=N82E16832116056
Hard Drive- I have a 20gig and an 80gig from old pc, reuse? I was thinking of the 20gig for the OS and adding two new ~150 (one for games, programs, junk, and the other for I-tunes and movies) good idea bad idea? Is the 10k rpm worth the money over a 7.2k?
-----Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM 16MB http://www.newegg.com/product/product.asp?item=N82E16822136011
----- Western Digital Caviar RE WD1600YS 160GB 7200 RPM 16MB http://www.newegg.com/product/product.asp?item=N82E16822136062
Optical Drive- Have a external DVD-RW drive and a internal CD-RW from old pc, will add a Blue-Ray later
Monitor, Mouse, Keyboard- Have from old pc, may get a 22” widescreen and gaming keyboard later. No rush though, any keyboard works, and my HD TV will do good for now
Anti-virus, Spam protection- I have no idea in this department. What do you recommend?
Memory- How do you tell what is good? Is the top dollar better than the cheapo kind? I want 4gig total, but will likely buy two 1gig sticks for now and get two more later. Here is what I was looking at-
-----CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/product/product.asp?item=N82E16820145589
-----CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/product/product.asp?item=N82E16820145590
----- G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/product/product.asp?item=N82E16820231098
What I’d like to know is-
Will these all work well together?
Is this a good build that will last, games and speed?
Is this setup a good mix of max performance without getting the most expensive parts?
Should I look into Video card/Memory cooling units?
What am I forgetting?
Any advise/tips for first build?
I know I don’t have a Power Supply on the list. I have no idea how to understand them yet. What will have enough leads for my rig? Is it possible to run two at once? Good idea, bad idea, overkill, not possible?
ideally something that looks good in side window. This maybe- http://www.newegg.com/Product/Product.aspx?Item=N82E16817190012
What am I missing?
Thanks for any help.
Eric
What am I missing?
Eric
