Need help, and advice on hard disk partitions
darlo2k4
So first things first, I have a Dell laptop with a Intel Celeron processor inside. My hard drive is 250gb, and i have two partitions - one which has vista on, and is 164gb, and one which has W7 on it, and is 50gb. The other gb are used for recovery, and i have 7gb which i took off the vista partition and planned to use it to extend my w7 partition. Except it won't let me, as the extend volume option is greyed out.
But i never use vista nowadays anyway, so ignore all that. Basically, i need to know how to remove vista off the first partition, then join that partition with my w7 partition.
As you may have guessed, and i'm a noob at this kinda stuff :P.
Cheers
Adam
