Need help, audio drivers.
elfasa
hi guys, my computer died recently and so i had to re install xp. (its xp pro if that makes a difference.)
my problem is that i cant install a sound card driver. when i try and install it it says:
the software you are instaling for this hardware:
has not passed windows logo testing to verify its compatibility with windows xp (tell me why this is important)
continuing your installation of this software may impair or distabalise the correct operation of your system either immediately or in the future. microsoft strongly reccomends that you stop this instalation now and contact the hardware vendor for software that has passed windows logo testing.
[continue anyway] [STOP installation]
ive tried continuing but the computer then becomes unusable, glitching at everything.
pleeeease can you help me sort this problem.
my motherboard is the intel d865gcl, and i have tried downloading lots of different software, mainly the realtec stuff, and soundmax.
thanks, tim.
