Need help connecting USB printer to LPT port!!!
Scrat
Hi guys......and gals
I have a HP Colour LaserJet 2600N that only has a USB port.
I need to connect this printer to my SUN Blade computer via the Parallel port... the software/system im using does not support using a printer via the PC's USB port, only the parallel port?
Can anyone help me? i know you can get an adaptor to connect a PC's USB port to a Parallel a Parallel printer but i cant find one that does the reverse!?
thanks,
Scrat
No clue about those but there are USB to LPT converters. Though, you probably need drivers and I don't know if that would work too well. Have you considered using some sort of network print server?
