I've been planning to buy a custom built PC for the last few weeks and I've only recently decided that I want to build my own after seeing how much money it could save me. I've put together a build but I have no idea if the components are compatible/if the motherboard fits in the case etc etc
please let me know if there's anything wrong with the build or if there's anything you would change due to cost/performance reasons- also, I'm buying the parts from scan because I want to use scansure so it can cover me incase i mess up and it allows me to pick the parts up from their store in bolton
thanks!
edit: i'm also looking for an internal wireless card that would be compatible with the build if anyone can help me w/ that
thanks!
