Need Help FindingA Good Heat sink fan.
Hewmunga
I broke my stock intel heat sink fan so i need to find a good aftermarket hsf
Only problem is i need find one that will fit in my GA-EP45-UD3P Motherboard as well as in my Antec 900 case
Anyone have same motherboard and case? if so what hsf did you use for it?
looking at around $40-$60 for it
I just wanna make sure it will fit in my mobo as and case before i order hsf
