need help installing a pci-e wireless card
You'll need either a pci version or a usb version. And there isn't much to choose from in the pci version as its getting outdated.
You don't need a PCIe x4 slot for it to work. You can stick a PCIe x4 card in a PCIe x16 slot. As long as it is PCIe you can stick it in any PCIe slot that it would fit in.
Yea you can stick a PCI-E x1 into a x16 slot.
Unless you have something occupying the last slot, you can install it in that.
